Home > Maintenance & Mods (L322) > Tow bar key
Nelly
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
Tow bar key
And another question
Got a westfalia tow bar with no keys, now I know you can order replacements on line, but I don't seem to have the correct code that they require.
Is there anything I can do, short of getting master keys
Cheers
Post #478099 11th May 2018 10:35pm
Is the key number not on the tow at lock barrel? Or am I imagining that? Failing that Call westfalia https://www.westfalia-automotive.com/uk/contact/
Worth an ask. There is nothing that can't be fixed with a hammer😜😜
Post #478102 11th May 2018 11:11pm
Nelly
I have looked on the barrel, but it covered with some black 5hit, so got some thinners out and cleaned it a bit, but can't see anything yet
Post #478108 12th May 2018 7:26am
How good is your eyesight and how well lit is the area ?
I find it easier to take photos & then zoom in for a proper look
As NMJ says - Westfalia should be able to tell you exactly where to look.
Post #478110 12th May 2018 8:30am
Nelly
Lol yeah eye sights pretty good, but I will have a better look today, there are plenty of codes /numbers over the tow bar, but I believe the number I need is on the barrel
Post #478111 12th May 2018 8:35am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Yes number is on the barrel. Just checking, because its happened to many others, but you have checked the key isn't in its slot in the Towbar storage compartment (right hand boot space under the floor cover in the wheel arch? Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #478114 12th May 2018 8:50am
Nelly
Er no I didn't even know that, hopefully it's there Bow down
Post #478115 12th May 2018 8:58am
Nelly
I will be out there later on, as I'm going to take bits apart on the rear and fix them.
So will have a real good look then
Post #478116 12th May 2018 9:00am
Nelly
Nicksaab, you was right (didn't even know that compartment was there) keys is in there, and the other one is snapped in the lock, so what are my options
Drill the lock, would this mean the Swan neck is still usable
Or I guess buy a whole new assembly
Post #478119 12th May 2018 10:49am
You can un-bolt the assembly from the receiver and take it out - though may take some effort if it's been there a while.
It's then easier to work with on a bench or take into a locksmith & see if they can get the key out.
Post #478120 12th May 2018 10:51am
Nelly
I did have a look at that, but don't have a 26mm socket(I think that's what it is)
Post #478121 12th May 2018 10:52am
Nelly
So might take it down my mates Garage one evening and use his tools
Post #478122 12th May 2018 10:53am
nicksaab
Good to hear! So the next silly question - is the lock actually locked? There are two parts to the towbar lock gin mechanism - the red and green tabs to show its fully latched and then the key to lock it. Its not recommended to not lock it with the key, but its doesn't need to be locked for it to operate safely. The one I would suggest is drilling a tiny pilot hole into the visible part of the key and putting a small self tapping screw into it and try and extract it with pliers. Current Fleet:-
Post #478127 12th May 2018 11:44am
Nelly
Errrr to late, I was trigger finger and have drilled the whole lock out,
But still can't get the tow bar off Big Cry
Post #478128 12th May 2018 12:02pm
Stuck tow bar thread Thumbs Up
Post #478131 12th May 2018 12:23pm
