![]() | Home > Maintenance & Mods (L322) > Idiots have been at work |
Nelly Member Since: 02 May 2018 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Looks like an after market camera has been fitted. On one of the many replacement camera threads there is a pic of what wires go to what. You change the new camera wires and wire it into the orginal wiring and one lead connects to the coax Current 2007 TDV8 Vogue Buckingham Blue |
You could be right, I did re solder the connections but still don't work, so gonna get a cheap one off ebay, it an NSTC (or whatever it is) one I need,? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8106 ![]() ![]() ![]() |
You need to fill your car details in - on your profile - there are different cameras across the years |
Done |
Does this thread help ?
Thanks for the link mate, those are not available now,
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Dont get one with built in Leds.
Ah OK, thanks for the heads up,
Try and get one that is NTSC only otherwise picture issues arise. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Thought that one was, will check 2007 range rover vogue, Black with issues
It says pal/ntsc 2007 range rover vogue, Black with issues
NTSC only, not both. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Sorry my mistake
