Home > Maintenance & Mods (L322) > Rear Light Cluster
SinbadRose
Rear Light Cluster
Hi All, just a quick one. Looked at lots of vids to remove a rear light cluster, 2 bolts , but do you just then pull it off, as i cant see the small indents that you would then put pressure in to pop it out. does it just need a small screw driver to prise it out.
I want to re-seal, as it has water inside, and looks a bit naf
Cheers
Post #478215 13th May 2018 8:50am
Yes - undo the 2 on the inside and it should slide towards you - may need a little leverage if its been there for a long time.
Post #478227 13th May 2018 9:15am
There is two prongs on the back of he light which go into grommets on the rear wing. Take out the bolts and the light basically slides out backwards. The indents should be on the light on the rear wing edge. Thumbs Up bit not sure if there are any on the 2011
I would use something more protective than a screw driver to prise it or you could damage the paint. There is nothing that can't be fixed with a hammer😜😜
Post #478228 13th May 2018 9:15am
I cut a thin wedge out of softwood and then tapped it in the gap to gently drive the lights forward and off the clips. No damage to anything. I would suggest greasing the clips before putting the lights back in place, makes it easier to remove next time. Thumbs Up
Post #478231 13th May 2018 9:24am
p38arover
Australia
The socket into which the ball joint slides (on my 2004, at least) can become brittle with age. Mine broke when levering the light out. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #478232 13th May 2018 9:28am
SinbadRose
Thanks for the quick reply's guys, I will go and sort it while we have sun light in the north Smile
Post #478234 13th May 2018 9:31am
SinbadRose
Is the unit fully sealed, or do you just undo the 4 t20's and it opens?
Post #478235 13th May 2018 9:49am
SinbadRose
Left the bolts, used hot air to go through the 2 holes after removing the rubber covers on the back, all dry, resealed and fitted back, cheers guys Smile
Post #478253 13th May 2018 1:13pm
