Home > Maintenance & Mods (L322) > 2007 TDV8 Coolant Leak
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
After moving the car this evening I spotted a damp patch underneath it.
On removal of the undertray it appears to be leaking from the hose at the bottom of the small radiator under the drivers side headlight. First of all what is the small radiator for and secondly has anyone else had a similar problem ?
Post #478295 13th May 2018 9:04pm
rar110
I’m pretty sure the trans cooler is on the driver side behind the bumper. But don’t think it has coolant running to it. The coolant reservoir is on the driver side. Either a code or the plastic container might have a split. ______________________________
Post #478301 13th May 2018 9:47pm
rar110
That should read hose or container. ______________________________
Post #478302 13th May 2018 9:49pm
if you take out the drivers headlamp you can get to the narrower hose off the bottom of the expansion tank. On mine it was chaffing and almost leaking. Have a look as that is a common leak spot and its near where you are saying.feel down it and you should be able to feel if its been chaffing. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #478304 13th May 2018 9:53pm
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
I have the ‘air blast cooler’ on my 2007 TDV8
The only info I could find was -
An additional air blast engine oil cooler is mounted in the RH front wheel arch for enhanced oil cooling performance at high speeds (supercharged derivatives only).
Not sure on the supercharged only statement, also worth checking the tank cap as there’s two different types and it can leak
Post #478309 13th May 2018 10:42pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Yeah, not just supercharged as my TDV8 has one. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478314 13th May 2018 11:48pm
Jamiehol
Unnecessary quote removed
Thanks for this, the leak looks to be coming from the hose on the bottom of item 11 in this picture. The hose itself looks to have swelled a little so I will play it safe and order a new hose.
Post #478323 14th May 2018 6:52am
