Home > Technical (L322) > Easy entry
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Easy entry
Hi, my car has developed a niggle in that easy entry function is only partially working? After the turn-off or turn-on, the seat drops and rise`s but the steering doesn't move? The Collom move`s manually ok,
Any ideas folks?
Post #478329 14th May 2018 8:49am
j_rov
It might be that it's position is not deemed in the way so it doesnt retract.
Try this, set the column to the lowest (towards thighs) and furthest out (towards driver), and set a memory position.
Then turn ignition off, then start engine, then stop engine then unlock and open door. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #478342 14th May 2018 11:44am
