Home > Technical (L322) > Gearbox issue (zf)
alistairh
Gearbox issue (zf)
Tonight I’m ready to pull out of a junction from a very steep incline. Boing transfailsafe.. locked into 4th gear .. pull over and read faults.. main ones a general stall speed fault? I hesitated leaving the junction then shot away .. any idea if cars system can get confused? Cleared fault and
Cars been perfect.. 160k and box was flushed in November.. very little debri on magnets as well..
Post #478990 20th May 2018 8:47pm
alistairh
Checked oil level today and was able to add a litre of fresh oil. Must have been underfilled when flushed in November.. no leaks from gasket ect.... wondering now with car being on incline when trans failsafe kicked in had a factor with low levels?
Post #479049 21st May 2018 3:34pm
sounds probable, time will tell. ... - .- -.
Post #479052 21st May 2018 3:41pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Any further problems? I have the same symptoms
Post #503521 1st Feb 2019 12:32am
