Home > Technical (L322) > differential oil seal
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
Hi all, I have to change the front differential oil seal, where the wheel joint fits, but I do not find it as a spare part from the land rover, how can I find it?
Thanks in advance
Post #479055 21st May 2018 4:44pm
ask our site sponsor dan @ duckworths if he can supply.. ... - .- -.
Post #479059 21st May 2018 4:57pm
RRPhil
Do you mean the lip seal identified with the callout ‘3254’ in the Microcat diagram below?
If so, the part number is TZB000050. Costs less than £10, here in the UK.
Phil
Post #479104 22nd May 2018 12:35am
madcima
yes, just that, thank you so much !!
Post #479114 22nd May 2018 6:14am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Just had mine changed last week was charged £60 for the whole job seal/oils etc as it was weeping a little Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #479138 22nd May 2018 2:36pm
madcima
very favorable price !!!
Post #479142 22nd May 2018 4:17pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Madcima have you changed the seal? How hard is the job? Noticed that mine needs replacing too.. assume it's a drive shaft off job.
Any tutorials? Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #479432 26th May 2018 8:49pm
madcima
For a user who has never done it, it takes 2 hours, I did not do a tutorial, too concentrated in the replacement, I can say that:
you have to remove the hub with the differential all attached, disconnect only the steering rack, and the rear arm while the center arm must be left attached to the hub
Post #479503 28th May 2018 9:18am
madcima
and what is very important, when the transmission shaft is inserted, it must be placed in support, and pushed inside until it feels resistance, then with a hammer it beats on the collar of the differential (edge) because the seager must fit inside (the edge of the differential must be equal to the gearbox
Post #479505 28th May 2018 9:26am
scotcruz
Assume you would need to get the alignment done? Or did you leave the strut bolts in situ?
Also how hard was it to take the half shaft off? Did you just take the shaft off from the differential side?
Please advise Current:
Past:
Post #479571 29th May 2018 1:28am
madcima
yes, I have removed the differential side shaft, there is no need to do any training, because only the rack nut is unscrewed, not the whole arm.
below is an image of how it should be pulled out.
Post #479572 29th May 2018 6:53am
scotcruz
Thanks Madcima.. from the image above I would have imagined tracking would be required as the two bolts to the strut would control the camber.
I wished I had tackled this job when I was replacing my control arms last week Big Cry Current:
Past:
Post #479573 29th May 2018 8:06am
