![]() | Home > Camping, Caravanning and Holidays > Removing dent from tin tent |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
Anything is possible, but depends where it is etc - may need an entire panel replacing.
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
I had one, admittedly lower, and put a self adhesive amber side reflector/marker over it that matched the other factory ones
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
I think the main problem with a caravan, unlike a car is that you can't get behind the panel to push the dent out. |
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 680 ![]() ![]() ![]() |
Adhesive reflectors rule |
Knocking dents out from the inside are long gone, if its that bad it panel replacement.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Nope, is the answer.
Funny you should mention that nmj, this is the first Lunar van we've had, and guess what ? It leaks |
Seems to be the way of things. The big manufacturers are trying to compete on water ingress warranty length but have yet to actually figure out how to stop them leaking.
Cheers nmj
Speaking of Leaky..... woke up this morning to child No1 complaining that their duvet was wet. Bleeding Heki light is leaking.....Again.
The joys of the mobile abode |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Aluminium dent repairs are getting better now that some cars are made from aluminium. There are a few YouTube videos showing someone removing dents from a Bentley tailgate and a Maserati door. Only problem as has been said is getting behind it as caravans have insulation. |
