![]() | Home > Maintenance & Mods (L322) > Serious White Smelly Smoke...THICK FOG! |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 ![]() ![]() ![]() |
Hi Everybody!
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Smoke and no oil in the engine points me to head gasket failure and if really unlucky cracks in the cylinder head. Could be piston rings or valve seals but I'll go for the head joint area.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1858 ![]() ![]() |
Fill the engine with oil, start the engine and pull the dipstick out
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Just my pennies worth but white smoke that smells can also be unburmt diesel 2015 4.4 AB
Thank you all.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
I believe it will come out the dipstick hole when you pull the dipstick out with the engine running.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Interestingly BmW already had the vortex breather way before the launch on the L322 as I have one on the M3 which is a 98... There is nothing that can't be fixed with a hammer😜😜
Hiya,
Crank case breather same as PCV |
[quote="mjdronfield"]I believe it will come out the dipstick hole when you pull the dipstick out with the engine running.
Sorry but Ive been on holidays....
One reason could be turbo seals blown or other issues with a turbo leaking, in my case an impeller shaft snapped letting the oil into the exhaust. 2015 4.4 AB
Thank you. I need some info on looking to see which is |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I'd avoid starting yours again until you diagnose it because if the above happens to you then your engine will be toast.
