![]() | Home > Technical (L322) > Auxiliary transmission cooler location recomandation |
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276
I doubt very much you'll need it - we've been towing with Range Rovers for over 10 years now and have never had a problem with the gearbox overheating. As long as nothing is clogged (sludge in radiator bottom) you should have no problems.
| nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560
The 4.4 V8 is a brilliant towcar and my 2004 has 196k on the clock - a lot of it towing. I also wouldn't personally worry about an auxiliary cooler - as Stu says, you'll need the money for a load of preventative maintenance
| Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142
Good advise above, I would add fitting a lower temp cooling stat. This will bring down running temp of both engine and gearbox. No7 - 2003 V8 Vogue |
| Bronjen Member Since: 13 May 2018 Location: DE2 Posts: 44
Many thanks for the advise, have just obtained the lower temp thermostat and defo going to change transmission oils, any recommendations on best price or suitable alternative to land Rover transmission fluid? |
This one only for the gearbox. Use anything else and you will have trouble.
Many thanks will get some this weekend |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
You may as well change the filter for a new one if you are going to the expense of changing the fluid, I think the genuine one is a filtrans |
Picking filter up from my local friendly independent on Monday |
Make sure it’s a genuine or OEM. |
| All times are GMT |
