![]() | Home > Technical (L322) > Suspension calibration problem |
| Minilee0 Member Since: 11 May 2018 Location: Cambridgeshire Posts: 22
Anyone local to Peterborough got diagnostic equipment T4 or something similar? |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Not quite sure how the autologic enters measurements or handles calibration, but normally you should calibrate, then adjust heights.
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
When I lowered mine I just entered -15mm using the IID tool.
Hi all and thanks for the replies, it’s set at 720 in the ecu and we wanted to increase to 840mm or std height , this is measured from the floor to top of the wheel arch , but as soon as the new value is entered and accepts it you then go back to main menu and then back to height calibration it’s back at 720mm ! |
| Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1484
Is he entering +120 or 840?
Ok it’s coming up as 720mm measurement from the bottom of the wheel rim to top of the arch and we need from the top of my head 840mm as std ride height , because I have 22” wheels on with 295:30/22 tyres on and want to revert to 19” wheels with 255/55/19 tyres . This is using Autologic equipment . Thanks all . |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
put the 19'' on and see how it looks... ... - .- -.
I’m getting a measurement of 430mm from hub centre and the rolling radius of the 19s is larger than the 22s |
I'm with Stan, put the 19's on and then make any adjustments.
Using
Yes thanks Joe90, it is 720 from Bottom of rim the problem I’m having is increasing the value on Autologic and getting it to accept it as it just reverts back to 720mm !
| All times are GMT |
