Thanks Joe,
Much appreciated, it was a bit daunting at first, the hardest thing was getting those bloody tank covers off, like you i did cut the rear lips away but kept the rear fixings in place, refitting was a doddle. Once i got stuck in things flowed nicely. Your "how to post" was a great help .
Hi, Paul,
No, formed them up as I went along, the R/N/S was one continious line, I formed the mushroom then capped it off
and fed it through from under the bonnet through the existing route and left it straight until I made the connection at the rear, then formed the curves and finally cut it under the bonnet, formed the mushroom and connected up.
This was the same method I did for the R/O/S, would have liked to use a single run but as you can see i had to do it in 2 parts the inline joiner is protected by the N/S tank cover when it was refitted.
When I had finished my thumbs and fingers were hurting like hell but it was well worth doing.
The only one I was able to preform and fit was the F/N/S (see pic). I used the original one as a guide.
 | | Click image to enlarge |
