![]() | Home > Technical (L322) > On plug coil resistance reading |
Marksman Member Since: 24 Dec 2010 Location: Durham Posts: 73 ![]() ![]() ![]() |
No one any info ? strange for this site |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
sorry mate, cant find anything on rave and a suspect no-one knows.. ... - .- -.
Thanks Scary, I thought as much, I have rave and nothing to be found but I'm sure I have seen something on the site refering to coil resistance values or the light throttle missfire problem.
i put 'coil resistance' into the search and a few things popped up , the results will make more sense to you than me. ... - .- -.
All reading between 1.1 and 1.3 ohms so nothing appears untoward, plugs changed and the oil removed from the spark plug wells (cam cover gaskets to be changed £180 all in by landrover) I think the slight hesitation may be torque converter on the way out |
