Home > Technical (L322) > 2011 4.4 TDv8 Judder
joslyn
United Kingdom 2011 Range Rover Autobiography TDV8 Stornoway Grey
Hi,
I have a 2011 RR 4.4 TDv8. When coming off the throttle at motorway speeds, or cruising with a very slight amount of throttle open, the car will judder. It's a single judder, only lasts for a fraction of a second and feels like the car has had fuel cut off, or the gearbox is between gears.
Absolutely fine under full throttle and all other normal driving conditions. Garages have struggled to replicate and therefore cannot diagnose.
Help, any ideas?
Thanks in advance...
Post #480428 8th Jun 2018 2:04pm
yep, mine had that...theres a TSB that involves a software update, LTB00054v2..
my experience,
http://www.fullfatrr.com/forum/topic38291....hesitation ... - .- -.
Post #480437 8th Jun 2018 3:39pm
as Stan said, theres is a software update to solve this.
Not sure if it is LR only, but I suspect most places with a decent diagnostic rig can fix it with an update, but it wont show a fault when they read the codes, they need to know what to do. if you give them the TSB code above then they should be able to find the software update from that. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #480482 8th Jun 2018 10:12pm
joslyn
Brilliant, thanks both.
Annoyingly it was in the main dealer with a description of the fault a while back and I asked for any software updates. They said they could not reproduce so did not do anything!
Post #480485 8th Jun 2018 10:42pm
Jamesonfox
Hi Joslyn,
Did the software update solve your issue? I'm having the same problem you described, though the judder happens at lower speeds too. There is no judder if I kick down the accelerator. But there is when I apply slight acceleration.
Post #644749 4th Oct 2022 3:17pm
garyRR
Sounds more like the torque converter to me but worth a try if there was a technical bulletin. 2015 Range Rover Autobiography 4.4 SDV8
Post #644758 4th Oct 2022 4:45pm
Jamesonfox
garyRR - Would a torque converter issue also cause a slightly rough idle? I also have a fault code indicating a misfire on cylinder 6.
Post #644767 4th Oct 2022 6:10pm
garyRR
A torque converter issue would cause juddering (even slight) when shifting to drive and when pulling off at slow speed or a slow coast.
I mean, it's worth a software update because even at Land Rover main dealer prices, I can't see them charging more than the diagnostics fee (likely <£200) whereas a recon torque converter fitted is c. £1,000+. 2015 Range Rover Autobiography 4.4 SDV8
Post #644768 4th Oct 2022 6:14pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Same here. Its common fault on 4,4. I was asking JLR, they say yes, we know what to do. But still have no time to go there and fix it.
And yes, sometime (very rarely) judder also with low speed as well. Its not torque converter, its just cut off injection for a moment.
Post #644769 4th Oct 2022 6:23pm
Jamesonfox
jaguar3 - so what's the fix for this problem? Is it just a software update, or cleaning the injectors or something else entirely? Previously I had a leaking charge hose to the throttle body and a very tiny hole in one of the four short rubber hoses to the donut, all of which I have since replaced. I have also cleaned the MAP and MAF sensors. However, this judder and the P0306–00 (26) fault code remain.
Post #644770 4th Oct 2022 6:44pm
Updating software won't fix your misfire issue, I think you need to get that sorted first.... Thumbs Up Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #644777 4th Oct 2022 7:13pm
jaguar3
I have not deepened in this problem, so canot say. Just JLR say they know what to do. Iam not driving very often on highway over 120kph (no highways near my), so its not critical to me. Up to 100kph no problems at all.
At lower speed that happened very rarely (2-3 times only as I remember).
I was asking JLR a year ago, so not remember exactly, but they say something about miss of communication between engine and gearbox...or someting like that. But yes, they promese to fix just by updating something.
Due I dont need to drive often fast, still didnt fix it Sad
Post #644781 4th Oct 2022 7:39pm
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Had the same problem with hesitation at low speed and sometimes at higher speeds on cruise control. Had a gearbox software update by a local independent, fault has now gone and gearchange much improved. LTB00454v2 - Engine Hesitation/Powertrain Control Module Update (various issues) 2004 TD6 - Gone
2011 4.4 TDV8
Post #644987 7th Oct 2022 10:09am
Jamesonfox
To test the injector in cylinder 6, I switched it with the one in cylinder 7. Still, I received fault code P0306, “misfire detected in cylinder 6”. How strange, I thought.
A friend then suggested that the fault code in fact is indicating a misfire in the 6th position of the cylinders’ firing order: that being cylinder 3 on the TDV8 4.4 engine. Accordingly, I switched that cylinder’s injector with the one now in cylinder 7. However, P0306 still appears, along with a rough idle, fluctuating RPM and a smell of unburned fuel.
I have also checked for continuity on the wires going to the injector in cylinder 6 from the ECM. No apparent issues there.
Is there another way I can test the injectors’ harnesses for short circuits?
Save for doing a cylinder compression test, what other steps could I explore?
Post #645072 8th Oct 2022 12:55pm
JayGee
Can you smell diesel in the engine bay or is it in the exhaust? 2012 TDV8 Vogue (L322)
Post #645073 8th Oct 2022 1:05pm
