Home > Maintenance & Mods (L322) > LED Side and Reverse light bulb
Zain
Thinking of changing both the Side lights and Reverse lights to the canbus error free LEDs. Will they both flicker on start up?
Post #480454 8th Jun 2018 6:35pm
mjdronfield
Never done either, but I don’t think the reverse lights will as I’m pretty sure they are not monitored. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #480455 8th Jun 2018 6:44pm
My sidelights are supposed to be canbus free but they blink (cold monitoring - which can't be turned off with iiDTool) when not turned on. I tell people it is a security feature Wink
Reverse lights are also canbus free, but never seen them flicker. - Get the best ones from Grofus on the forum Thumbs Up .
Post #480477 8th Jun 2018 9:52pm
peejay
England 2009 Range Rover Vogue SE TDV8 Santorini Black
I put in Grofus reverse LED's and they don't flicker, put canbus free in front sidelights and they flicker when I first turn the ignition on for a few seconds (without turning the lights on!) then stop after a few seconds.
I put different make as DRL's in my VW Transporter and they don't flicker!
Post #480496 9th Jun 2018 6:58am
Zain
Think i'll stick with normal 501 w5w bulbs up front.
Anyone got a link to reverse light LEDs which are a straight swap?
ta!
Post #480529 9th Jun 2018 8:07pm
have a look in group buys for the plug'n'play reverse bulbs.. ... - .- -.
Post #480530 9th Jun 2018 8:35pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
I have LEDs in the reverse lights and they do flicker when you turn on (my brothers do too). You get the occasional flash as you drive along too.
Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #480721 11th Jun 2018 8:43pm
