Home > Maintenance & Mods (L322) > Outer window seal
dirtymonkey38
Outer window seal
Hi, my drivers window is trapping the window seal on the outside, looks like passenger side will start to do the same soon.
Has anyone changed theirs, and are they easy enough to do? What am i looking for in regards to part name?
Thanks in advance
 2011 RR Autobiography 4.4 TDV8
Post #480618 10th Jun 2018 6:54pm
mine did that on my old SC...from memory its pulling the old trim off and push fitting on the new..... ... - .- -.
Post #480638 10th Jun 2018 8:33pm
dirtymonkey38
£85 for drivers side. £95 for passenger side. Wonder what makes it £10 different. Smile 2011 RR Autobiography 4.4 TDV8
Post #482111 28th Jun 2018 5:29pm
you could try pulling the old one out putting it in the sun for a bit and refitting it with a bit of gummi pfledge on the inside edge, before spending £200 on 2 rubber strips. worth a shot, might work. There is nothing that can't be fixed with a hammer😜😜
Post #482188 29th Jun 2018 1:18pm
dirtymonkey38
apparently its a glass out job....anyone know if thats the case? 2011 RR Autobiography 4.4 TDV8
Post #484006 21st Jul 2018 8:31pm
