![]() | Home > Technical (L322) > E G R PROBLEMS |
disco 3.5 Member Since: 14 Aug 2014 Location: barton seagrave Posts: 39 ![]() ![]() |
hi all, my engine management light has come on, took it took a local garage for diagnostic check and the code came up as e g r fault, have been advised to giv e the car a good long run because they believe the egr dont like me just doing short little runs all the time, the engine management light was off when i picked the car up so i head off to give it a good run. 5 minutes down the road descided to open her up a bit soon as i put my foot down the enginemanagement light came back on, the garage said if this happens i will have to replace both egr because they wont know which ones at fault, is this good advise, if it is how much am i looking at to replace them many thanks LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
have a remap and blank the EGR and its cooler , you wont regret it and its probably cheaper to do too |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Try induction cleaner. I used Revive. It’s available in uk. Then remap to disable EGR. ______________________________
http://www.autosessive.com/blog/index.php/...-reviewed/
is remapping it legal. will it pass the new mot
take you caps off please pal , no remapping is not illegal and wont effect MOT |
cheers bembo 449 having it mapped out and blanked not affect the engine ? LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
well yes it will ,better performance , better economy and smoother running , there are no downsides if you do the full mod pal |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
If it's a 3.6 then your best option is to have the EGR's removed and blanked and then the car remapped to accommodate.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
MoT testers are not allowed to remove covers. As long as the top engine cover is on, there is no way to see if you have EGRs enabled or not.
