![]() | Home > Technical (L322) > Help!!!!!! |
| MattC Member Since: 27 Oct 2016 Location: Surrey Posts: 25
Check the top right rubber hose from the intake manifold. Take off the plastic engine cover and it the further towards the windscreen on the right hand side- they have a tendency to split. You should be able to either feel the split, or feel oil leaking out.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
| VIRGIN Member Since: 04 Apr 2018 Location: SOUTH WALES Posts: 10
Thank you for your replies, its been a great help |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
welcome to the forum - stick around |
Thank you |
Well over 50 4.4tdV8 owners on here to help you by sharing experiences and knowledge.
Thank you Mike, I'll post the solution as soon as I find it
The original 4 hoses are very soft pliable rubber, but the replacements are much tougher.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
the EGR open circuit is a ghost fault too. It crops up on several cars on here and there is pretty much a "they all do that" from time to time attitude from LR. I would doubt it is the cause of your fault. Much more likely to be boost related. While you have the engine cover off check and clean the MAP sensor on the intake plenum. Its the sensor with the red arrow pointing towards it on the pic above. It can get gunked up and give false readings of the pressure in the manifold. which can cause issues too. Bit of contact cleaner should clean it up. just take out the torx screw and the sensor pulls out.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Where does one purchase said replacement hoses from chaps? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
ask dan at duckworths in his section. |
Dan’s the man |
Great! Learning lots. Appreciate all the help and advice on here |
http://www.fullfatrr.com/gallery/albums/us...G_1518.JPG
| All times are GMT |
