![]() | Home > Technical (L322) > 2007 Tdv8 rear wobble |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35875
my guess would be to check the tyres for bulges or warping and the wheels for any damage ... ... - .- -.
| SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128
Thanks Stan
thats a good plan..its a process of elimination. ... - .- -.
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276
In addition, I think I'd be inclined to jack up the rear wheels and give them a good wobble to look for any worn bushes/joints etc or anything that looks out of whack just make sure all is Ok there. |
| finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120
From what you describe, it could be the rear hub bushes. Do a search on here. |
Thanks guys
| Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714
+1 on checking the rear bushes / ball joints.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Check the rear brakes for excessive heat after a run. Could be a binding Caliper. There is nothing that can't be fixed with a hammer😜😜
It’s done 115k so the back end may have some play. Would this give a sort of constant wobble/ judder feeling in the drivers seat at all speeds? |
NMJ
If the symptoms are more like a "judder", I don't think I'd expect it to be bush / joint related (even if they're worn) Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
Pawl
I saw your post about having the pads discs and callipers replaced. Still don't rule that out. when mine were binding it felt like what you are describing. It could be the pads sticking in the carriers rather than the calipers themselves. Causing them to bind on the disc slightly.
Cheers NMJ
