Home > Technical (L322) > Seat Height |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
MOH has just measured our 2008 Tdv8. Passenger seat is approx 76cm from the ground on access height.
16th Jun 2018 3:09pm |
MICKDEE947 Member Since: 30 Nov 2017 Location: nottingham Posts: 10 |
Thank you Weegie for a speedy reply
16th Jun 2018 3:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
i concur that side steps make getting in and out much easier if you have limited mobility.. ... - .- -.
16th Jun 2018 3:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Fitting sidesteps also benefits the shorter in stature, me included , and can reduce wear and tear on the driver's seat in particular (passengers also if used a lot) .
16th Jun 2018 9:25pm |
Thanks for the replies
16th Jun 2018 10:00pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
I don't know if this would help, or even if it's possible, but I'm sure I've read somewhere on here that you can use the IID tool to lower the suspension even further, onto the bump stops. 2017 4.4 SDV8 Autobiography
17th Jun 2018 8:02am |
@Mick, From your description side steps would be a problem. However, if you find an L322 with them on already, they are easily removed.
17th Jun 2018 8:28am |
it depends what year you will buy and if you also purchase a GAP iidtool..
17th Jun 2018 8:43am |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Hi MICKDEE947, I had the height you are looking for measured by the dealer when I was purchasing my 2010 L322, here’s the photo they sent me, sorry it’s sideways...hope it helps
17th Jun 2018 9:21am |
is this in " access mode " kgeddes ? |
17th Jun 2018 12:50pm |
Many Thanks for the above informed responses.
17th Jun 2018 12:59pm |
Hi Mick,yes, the FF was in access mode when the measurement was taken |
17th Jun 2018 2:45pm |
Found this on the Internet, hope it helps:
17th Jun 2018 2:49pm |
Thanks kgeddes |
17th Jun 2018 3:31pm |
