![]() | Home > In Car Electronics (L322) > Advice on sticking dashcam mount to windscreen |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
clean surfaces and 3m tape or sticky pads (ebay)..
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
I did similar, ensure the glass is clean and I used no more nails tape |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
3 Meters of tape!! That's an awful lot!!! |
very good Paul |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Pop into your local Autoglass etc, and see what they would recommend.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1481 ![]() ![]() |
Thanks chaps, going to pop into screwfix on the weekend |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Might also be an idea to heat the glass up to avoid any condensation issues in this cold weather. Got - 2017 SDV8 Autobiography in Loire Blue
Well, 4 months in and the |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Rob is the cable pulling it too tightly away from the screen?
The cables aren't really "pulling" at the dashcam and are mainly tucked into the headlining. I've tried genuine 3m pads, adhesives etc and they all work to varying degrees.
does this pic help Rob...it shows how the sensor cover lifts from the screen..
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
Have you tried a small suction cup as supplied by many dash Cams? Ours is fitted in our i3 (not got around to the RRFF yet) and it’s been in there since last September without dropping off, just make sure the screen area is clean and slightly dampen the cup before fitting. David
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Before fitting any device, suction cups or sticky pads I would suggest cleaning the screen area with methylated spirits.
ilard Member Since: 21 Oct 2012 Location: London Posts: 715 ![]() ![]() |
I would use a moistened clay bar to remove all contaminants, polish dry, then stick. You might be surprised by the amount of filth that’s actually on an apparently clean piece of glass. |
