Home > Technical (L322) > Seat Height
MICKDEE947
kgeddes wrote:
Found this on the Internet, hope it helps:
Transportation Mode
To enable the vehicle to be delivered safely from the factory to the dealership, the air suspension system is set in
transportation mode. When the engine is running, the ride height will be set at 'Transportation High', which is 20 mm
below standard ride height. All four LED's will remain illuminated. When the engine is not running, the air suspension ECU will drop the ride height by 50 mm (Transportation Low). All four LED's will flash. When the ride height is at 'Transportation Low' the vehicle can be lashed to a transporter, without the risk of loosening due to the suspension ride height lowering.
I think that is what I read also.
I was wondering what ACCESS MODE and TRANSPORTATION MODE were, as a comparison. I.E. how does the 50mm mentioned above, compare to the ACCESS MODE ?
Post #481171 17th Jun 2018 3:38pm
Not sure how easy it is to engage transportation mode. Its certainly not a standard button on the control panel, so how easy it is to activate it every time you want to get in and out of the car is the question.
Having a quick read of this thread http://www.fullfatrr.com/forum/topic47371....ation+mode it would indicate its a factory set thing which is deactivated when delivered. If activated it limits other functionality on the car. There is nothing that can't be fixed with a hammer😜😜
Post #481173 17th Jun 2018 3:51pm
Paul thornton
As Stan says, it depends what year you are looking at but with the 2002 - 2005 models you can set the access height pretty much as low as you want it using an IID tool leaving the running / off road heights standard if you wish.
With the later models, you adjust everything so for example of you lower the access height by 20mm, the running height will also be lowered by 20mm.
Post #481182 17th Jun 2018 4:52pm
MICKDEE947
Thanks for that Paul thornton
Post #481203 17th Jun 2018 8:39pm
MICKDEE947
Thanks northernmonkeyjones
Post #481204 17th Jun 2018 8:40pm
