Home > Technical (L322) > 2011 4.4 tdv8 alternator problems
Page 3 of 6 <123456>
Baltic Blue
Nino & dolph34,
I am taking mine for MOT on Monday, then intend to replace battery because I seem to be getting the low battery warning more and want to change it before it lets me down.
I think I will put the new battery on charge with my CTEK before resetting the BCM with my iid.
Thoughts??
Post #481412 20th Jun 2018 8:46am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi Nino, I'm still hoping others report back with thier IID results. If i read the ' intelligent ' alternator stuff correctly , the alternator does not send 14.4(ish) volts to the battery unless you are decelerating or the battery is low. My RR battery is currently ( lol) on 86 % , which is slightly higher than the 80% that the Land Rover literature says it should be. So my thinking is , when we got the new batteries they were 100% charged so the IID tool reading reflected that , as we drove the alternators ecu let the batteries stored capacity reduce to 80(ish)% and hence our readings now.
This morning I checked again and my battery was on 82%, on the journey the battery voltage remained around 13.1 and increased to 13.8 in acceleration and 14.4V on deceleration and that's exactly what the Land Rover literature says it should do. In arrival at work battery stored voltage had increased to 86%.
However , if a few more of the kind people on this forum could check their lives values for battery voltage and alternator amps during a drive we may get a better idea.
Regards, John 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481414 20th Jun 2018 9:15am
nino_nino
Mike are you going to replace battery by yourself? if so I have made a little device to help with exchange(saving one's back). I am out the door now but will do the write up later. Thumbs Up
Nino,
Post #481415 20th Jun 2018 9:21am
Baltic Blue
Gents,
Here is a copy of an email that I have sent to Pat @GAP.
I will share any reply.
Post #481425 20th Jun 2018 10:48am
Weegie
Mick, This post (5th in the thread) by GraemeS explains what is needed more fully than I did:
http://www.fullfatrr.com/forum/topic42331.html?highlight=untested John
GAP iiD BT-Sold
Post #481427 20th Jun 2018 11:45am
dolph34
Hi , my IID tool has always had the untested values , i assumed we all did. I did buy my IID tool directly from GAP as i part exchanged my non IID tool with them.
In fairness my mum always said i was special Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481437 20th Jun 2018 1:52pm
dolph34
Thanks Mick. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481438 20th Jun 2018 1:56pm
Baltic Blue
Gents,
Here is GAP’s reply.
(Very impressive response time).
Mike.
Post #481452 20th Jun 2018 2:38pm
nino_nino
thanks Mike,
but if they have known for the glitch why not worn us not to do reset, and what are we supposed do now?
lucky you Mike Thumbs Up
Nino,
Post #481457 20th Jun 2018 3:44pm
dolph34
Hi Nino, i dont think they said there is an issue, i think they meant the alternator has the ability to lower the charge if it determines the need to. Thats my reading of GAPS response. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481458 20th Jun 2018 3:49pm
nino_nino
love your enthusiasm delp34 Thumbs Up , you and me we'll just have to keep an eye on things. and if I was in Mike's place I would stay away from resetting.
Post #481461 20th Jun 2018 4:07pm
dolph34
Hi Nino, I was going to suggest to Mike that could monitor his charge rate now and see how its working once he get the untested values on his IID tool. If his also reads similar values than maybe we have an answer ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481467 20th Jun 2018 4:50pm
nino_nino
I believe that is exactly what Maki was going to do and after battery change falow values without reset- that way we can compare the values. maybe there is a silver lining after all.
I just did my IIDTool update and no untested values Big Cry
Nino,
Post #481468 20th Jun 2018 5:12pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
PM on it's way... http://www.gap-diagnostic.com/
Post #481472 20th Jun 2018 5:39pm
Salter121
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Sumatra Black
Very informative thinks
Post #481485 20th Jun 2018 7:41pm
