Home > General > Fog Light HID Upgrade
dan_uk_1984
Has anyone used an HID kit to upgrade their fog lights?
I'd like a whiter light from them and wonder if this is the way to go? I often use them when driving through the country lanes and want to see what's immediately in front of me.
Alternatively I could just go for some of the White/Blue standard H7 bulbs on ebay to get rid of the yellow tinge.
It's £80 vs £5... hmm perhaps just made my mind up.
Post #48194 30th Jan 2011 1:44pm
T24RES
Do the HID upgrade, they are far superior, and second best wont cut it............. Thumbs Up Ian
Post #48196 30th Jan 2011 1:58pm
I'm guessing you know you can get fined for using them in certain cases as they are only to be used in adverse weather ........... Law RVLR regs 25 & 27 Thumbs Up
Don't know why i have posted this coz you'll know ........... Laughing Laughing
Post #48197 30th Jan 2011 2:37pm
hongkongphooey
Isle Of Man
HID.
Because if you don't it'll just annoy you every time you turn them on. Thumbs Up
Post #48198 30th Jan 2011 2:58pm
dan_uk_1984
However - one can use them as driving lights when used in conjunction with main beam. Although technically I think they have to be wired to only come on with main beam...
I wouldnt drive through a town with them on, I want them for the increased visability...
Post #48203 30th Jan 2011 4:15pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
You could change them to LED foglight bulbs to give brighter whiter light and probably about a tenner?
Post #48208 30th Jan 2011 6:38pm
led's wont give the forward beam that dan wants nick...i've experimented with leds in my fogs and i finally decide to put them in my main beam and use them as drl's, very bright as you look at them but as i said no forward beam. ... - .- -.
Post #48211 30th Jan 2011 7:04pm
I'm getting a feeling we have been hear too many times but any hoo ,
HID bulbs DON'T WORK IN PARABOLICK REFLECTORS you get lots of light yes but it scatters all over the shop and not focused forward like people think they are achieving .
This is why proper HID lights have a focusing lens but if you want to light up the Owls in the tree tops fill your boots. 2008 MY Supercharged
Post #48217 30th Jan 2011 7:31pm
agree with AXLE , after market hids need 'projector' type housings ..
maybe DAN is getting the complete unit with the proper housing for hids.. ... - .- -.
Post #48222 30th Jan 2011 7:56pm
dan_uk_1984
OK, from reading up on it online and from what you guys have said - HID is not the way to go. Wrong beam pattern etc.
I might just try these "white" H7 bulbs.
What are the thoughts about the 100W bulbs? Yes I appreciate they aren't legal you nagging nannys! Will they melt the housing?
Post #48252 30th Jan 2011 10:04pm
T24RES
100w probs will distort lens over time. Had that problem with the early omegas when running 100w.
I put a HID kit in my lads car and it has the caps over the bulb that pushes the light back via the relector. A big improvement over a standard H4 hi/lo set up. Ian
Post #48253 30th Jan 2011 10:11pm
M44K TS
I'm ashamed to say, when I was a nipper, I had 80w/100w H4 headlight bulbs in the Mini, they had the blue glass on the bulbs, they were a really bright white, wrecked the headlights due to the extra heat and almost set fire to the wiring due to the extra current.
Simple answer, don't bother. These get quite a good review though....
http://www.halfords.com/webapp/wcs/stores/...yId_205263
Luckily, I do things properly these days. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #48255 30th Jan 2011 10:16pm
dan_uk_1984
So if it has the cap it's fine?
Like this:
Not:
This would be ideal, altho maybe the outer ring is a bit bling:
http://cgi.ebay.co.uk/H4-6K-White-Bi-xenon...1e5cf696ef
Post #48257 30th Jan 2011 10:24pm
T24RES
Its similar to the standard fog light bulb. In as much that the tip is coated so that the light is thrown to the reflector and not just anywhere. Thumbs Up Ian
Post #48259 30th Jan 2011 10:28pm
Nickj
Sorry to piggy back this thread but if i use LEd fogs (2002 l322) (main reason being i have a set that fit into the 2010 fog unit) will i need to use resistors to prevent dash error message. I'm guessing the answers yes as per evry led upgrade!!
Post #48695 3rd Feb 2011 10:58pm
