![]() | Home > Technical (L322) > [SOLVED] Testing Battery Drain Instructions Help |
| Kiamaria Member Since: 23 Jan 2018 Location: Cheshire Posts: 23
My battery drain didn't show up anywhere until i pulled the connector on the neg lead module. |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428
@Kiamaria
Definitely on Fuse 49, amperage dropped to 0.05 amps when pulled and car asleep.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984
Does you car have a Connect 2 box about the size of a packet of cigarettes in the wiring harness running below the TV module. It's part of the original car phone system. If so you could try removing it. Undo the two plugs connected to it and plug the plugs together. They are m/f and blue if my memory serves me correctly.
A good shout, but I have already removed it sometime ago and plugged the two connectors together |
More testing:
Try unplugging the aerial to the sat nav only. Leave the Satnav connected. |
Decided to dismantle the satnav unit, which was/is working, to see if anything obvious inside.....
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
I wonder how many Satnav units have been scrapped when all they needed was their teeth cleaned.
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3558
Great news Joe, well done!
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
Good find Joe. What is that mess? 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
I guess it is just corrosion from some previous water ingress, am guessing that this was causing a short of some kind, or quite simply, as often is the case |
| kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289
I’ve just had fuse 49 diagnosed for my battery drain issue. Still to confirm what component is the cause. Fuse 49 removed at the moment. Wish I’d seen this thread earlier! |
