Home > General > What tyre inflator do you use?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Ive got a cheap Ring inflator from Amazon, it was about £12 but it isnt really up to the job (plus its very slow, and bl00dy noisy too), just wondered what you guys carry with you or use to inflate your tyres?
Post #481981 27th Jun 2018 12:59pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
I use one of these Ring RAC900
https://www.amazon.co.uk/Ring-RAC900-Compr...s=ring+rac
It works great for the Discovery and Defender so I'm sure it will be fine on a RR Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #481985 27th Jun 2018 1:24pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
I have a Michelin one, but I do run the engine while it’s running. It does run faster and pumps tyres up a bit quicker
Post #482051 27th Jun 2018 11:02pm
One similar to this.
https://www.amazon.co.uk/Black-Decker-ASI3...ecker+tyre
Plugs into the wall not the battery. Slow and noisy, but you can leave it until it's done its job.
Post #482083 28th Jun 2018 11:09am
p38arover
Australia
At home, a 13cfm compressor with a British Jamec PEM tyre inflator/pressure gauge.
On the road, a compressor bought from, I think, Aldi. I used it a few times to pump up the suspension on the P38A. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #482088 28th Jun 2018 11:58am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I can't understand why LR don't have a plug in outlet on the onboard compressor. Then all that is needed is an airline.
I wonder how easy it would be to retro fit one. Idea 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #482263 30th Jun 2018 11:51am
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Cayenne has that ability from memory - never used it though 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #491702 10th Oct 2018 12:27pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I have a pump that was intended for space saver tyre kit, mine was made by Continental (or trade marked as such) but they are from Michelin as well, the power lead and air line pack up into the main body for storage and it is not very loud and much faster than a cheap pump bought before, have a look on eBay for one. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #491708 10th Oct 2018 12:58pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
just over 40 seconds of a ff wheel flat to full, not cheap but the best ive ever had. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #491711 10th Oct 2018 2:09pm
j_rov
^^^ DITTO ^^^ __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #491712 10th Oct 2018 2:28pm
paddy_ffrr
The Clarke units which combine jump start pack as well as compressor have served me well in the past... good value if you can stretch to it
https://www.machinemart.co.uk/p/clarke-jum...ompressor/
Post #491743 10th Oct 2018 5:28pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
big workshop compressor, cant remember how many cfm but it has a 400 litre receiver (dual motor job, came from a spray booth previously).
I also have a 50l carry tank (make by sealey I think), that I charge in the garage and then carry to each of the cars, it a lot easier than dragging out a hose to them.
I also have a compressor that comes from a Porsche 993 that I keep in the car. Its in a box about the size of a CD player.
I even carry a compressor on my motorbike, made by slime and about 100mm square. Pretty noisy but does the job when needed. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #491747 10th Oct 2018 5:46pm
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
Same as Hairy Dan, Ring RAC900 and I find it reasonable. The gauge reads quite accurately and it works quickly. I find the on / off switch on the unit is not very user friendly as I really want it near the tyre I'm inflating. As the nozzle screws to the valve you can't just release it as you get to pressure, so have to run to where the unit is to turn it off. Then unscrew the nozzle.
Post #491829 11th Oct 2018 6:54am
ive got one ive had for years from Costco. Its starting to see better days now but works well enough for the time being. Think it is a Bon-Aire one. Has a nice long Flexi hose with it. There is nothing that can't be fixed with a hammer😜😜
Post #492253 14th Oct 2018 3:21pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
probably becasue it would exceed the duty cycle and shut down for being too hot just puffing up one tyre. Cheers
James
Post #492380 15th Oct 2018 10:14am
