![]() | Home > Technical (L322) > General help required for an L322 Numpty |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Cant help on the others but for No 4 :-
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
1. Hopefully
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
5. ISTR a post on here lining to a chap who refurbs car RSE remotes - I am sure a search will turn it up |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
We'll also need pics of your new one.
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Mun, since your location says Reading, the people you need to talk to are Rovertune. I found them very experienced in all things Range Rover, and friendly honest guys too. |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
No 5
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 543 ![]() ![]() ![]() |
No 3
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
No 3
Mun Member Since: 17 Jun 2018 Location: Reading Posts: 16 ![]() ![]() ![]() |
Thanks, I will give that a go, I tried with the engine running and turned it lock to lock, but did not see any extra light. |
Thanks!! |
Brilliant, thanks ![]() ![]() |
Will give that a go, thanks! |
Here you go! http://www.fullfatrr.com/gallery/albums/us...PE4407.jpg |
On the adaptive lights , don't confuse them with the ' cornering' lights. Not sure if your model has them or not ( as an option) but on my 2007 VSE it had adaptive and cornering lights. The cornering lights came on sub 40 mph i think and basically light up the kerb / footpath from an extra bulb in the headlight as you turned . The cornering lights move the beam quite considerably as you drive. I used to show people by turning the steering wheel from side to side gently and the lights would move to each side of the road and if memory serves the lights work independently of each other. As in each beam moves one after the other l. I only realised I had the adaptive lights on a spirited drive along a tight country road. I thought i was seeing things and then discovered what they were. 2015 4.4 AB
