Home > Maintenance & Mods (L322) > Disc and pad contact
dirtymonkey38
Had new discs and pads fitted all round and done approx 100 miles or so. While driving around today with the windows down I’ve noticed a grinding/graunching noise up front, like something rubbing. Noticed it more when turning left and applying brakes. Had a look when I got home and all discs have an even band across the entire disc apart from the drivers side front which still has a good inch or so of non contact. Pictures below. All discs are Pagid with Textar pads, all new. Will be going back to the garage that fitted then but in the meantime, any ideas what the problem may be?
 2011 RR Autobiography 4.4 TDV8
Post #482358 1st Jul 2018 7:25pm
Hot sure about the band, but it could just be a stone in the back plate. There is nothing that can't be fixed with a hammer😜😜
Post #482360 1st Jul 2018 8:04pm
dirtymonkey38
Just given them a good wash down. I will have to go for a run and see if it’s any better. 2011 RR Autobiography 4.4 TDV8
Post #482363 1st Jul 2018 8:16pm
mpirie
Whoever fitted the discs may have bent the backplate, causing a light scraping sound.
Easy to check if you jack the car up and rotate each wheel.
Mike
Post #482393 2nd Jul 2018 7:14am
dirtymonkey38
All sorted now....a pin(???) had been put in the wrong way. now more shaking, squeals or grinding noises and after a motorway blast the disc that had a 2" ring where the pad wasn't touching has now disappeared. 2011 RR Autobiography 4.4 TDV8
Post #482443 2nd Jul 2018 8:09pm
