![]() | Home > Technical (L322) > Drivers door not opening |
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
At a guess the cable is probably stretched and near to its working limit when cold. It heats up, expands more and then wont do its job.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
Is it locking and refusing to unlock ?
| rik Member Since: 21 Jan 2015 Location: argyll Posts: 265
Ok so new cable was fitted last year and is working no prob when cold or at least when out of the hot sun .All other doors are working properly.drivers door is locking and unlocking as in making all the noises and button rising .Not opening from inside or out .If driven with door not opening for a few miles it opens normally . Opened and closes normally locks unlocks etc until left for a while as in going into shops and back out tried manual unlocking makes no difference.is intermittent in its fault which makes it frustrating. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
i dont think its the inner or outter cables, more likely the latch mechanism... ... - .- -.
Cheers stan I was thinking along those lines .Do you think a new mechanism or can something be done with this one? |
this kinda thing happens in the winter where the lock freezes and a strip and grease normally solves the problem..might be worth trying this first.. ... - .- -.
Ok so stripped and oiled latch .There is a part of latch attached to adjusting screw accessible from side of door through grommet. this bit moves up when unlocking mine did not fully move up and when helped with finger a click can be heard and lock opens must be a spring inside .A little rivet allows it to swivel so I oiled and worked it back and forward until it felt nice and free back together and all seems well for the moment sun on door today panel red hot and door opened easily fingers crossed |
| All times are GMT |
