Home > Technical (L322) > 2011 4.4 tdv8 alternator problems
Page 5 of 6 <123456>
those of you with dirty minds please refrain from commenting.. Laughing
looking forward to it nino.. Wink ... - .- -.
Post #481883 26th Jun 2018 10:51am
mpirie
That''s me silenced then! Whistle
Mike
Post #481967 27th Jun 2018 11:14am
Baltic Blue
I think I picked the hottest day of the year :rolllaugis h: , but today I have replaced my battery.
I have fitted a Varta G14 019 AGM , but not told the car yet, ie I have not yet reset the charging module.
Theses are the readings immediately after completion.
I intend to recheck it for the next few days and then decide whether to reset it.
Best tip I can give anyone, find a friend who is 6ft 5” tall with arm muscles like Popeyes on spinach.
Otherwise the job is fairly straightforward.
I removed the air box and checked down the back of the engine .
Post #482431 2nd Jul 2018 4:47pm
i have a neighbour called Olive, is that any good?...
did you use a nino plank Mike.. ... - .- -.
Post #482432 2nd Jul 2018 4:50pm
Baltic Blue
I had it ready to use, but Popeye just took a deep breath, grabbed the handles and lifted the old one out and the same fitting the new one. Bow down Bow down
As Nino said, no need to unplug this unit, just move it out of the way.
Post #482434 2nd Jul 2018 4:59pm
Baltic Blue
Please could someone post a picture of the red plastic cover for the + ve terminal on a 4.4tdv8.
Mine wasn’t covering the lug, just attached to the battery lead with a bit of plastic tie.
I was too hot after putting it all back together to investigate further, but will take another look tomorrow PM.
Something else worth a mention.
On the negative lug, their is a plastic plug with 2 very thin wires .
I couldn’t get the plug to part from the socket, but managed to move the whole lug and negative cable to the side whilst the battery was lifted out and the replacement dropped in place.
Post #482445 2nd Jul 2018 8:39pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
If no one posts by the morning Mike , i will take a picture, I'm out on the bike tonight and won't be home until late. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #482446 2nd Jul 2018 9:04pm
Baltic Blue
Thanks John.
I have to attend a funeral tomorrow morning, but will be trying to sort it later in the afternoon.
Post #482448 2nd Jul 2018 9:18pm
Baltic Blue
Also,
Nino, did you say yours didn’t have a cooling fan on the back of the unit.
You will see from my picture that mine did??
Post #482451 2nd Jul 2018 9:33pm
nino_nino
I was wondering the same thing, my doesnd't have cooling fan. i did find this plugs behind the battery.
Nino,
Post #482483 3rd Jul 2018 11:45am
dolph34
Hi Mike, Nino , mine has no fan either !! Pic to follow 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #482486 3rd Jul 2018 12:40pm
Baltic Blue
John/ Nino,
One possible explanation?
Early 4.4’s were not factory fitted with AGM batteries, but were re-called to upgrade from lead acid to AGM.
Maybe they decided fan was not necessary once they started fitting AGM’s ?
Mike.
PS
I have just rechecked my live values;
Post #482491 3rd Jul 2018 2:02pm
Baltic Blue
Their is no way that the red plastic terminal cover is ever going to fit properly on my car.
Post #482492 3rd Jul 2018 2:09pm
dolph34
My 2011 was manufactured in May 2011. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #482497 3rd Jul 2018 3:23pm
Baltic Blue
Mine has a build date of 03/03/2011.
The fan man was off sick the day they built yours and Nino’s Rolling with laughter Rolling with laughter
Post #482498 3rd Jul 2018 3:42pm
