Home > In Car Electronics (L322) > navcoder help required please
Shameless plug
http://www.fullfatrr.com/forum/topic47881.html
Thumbs Up .
Post #482447 2nd Jul 2018 9:10pm
Zulu 10
[quote="Shambler"]
Iโ€™m not sure how to do a link thingy so I took a screenshot of it ๐Ÿคฃ
Donโ€™t know if you can tell anything from that thoโ€™ ๐Ÿคž[/quote]
The interface which you have bought is designed to talk through the OBD port to various control units through K-Bus or CAN Bus. Hence it should work with INPA.
However, the means of connection of the various infotainment computers is I-Bus.
Unfortunately the I-Bus is not available at the car's OBD socket, so instead you will have to connect to the I-Bus by spicing into it in a less convenient place such as the left rear wing where the nav kit and much of the audio is located, or behind the dashboard.
The simplest way of connecting a PC to I-Bus is using the Resler interface as offered for sale by another poster (above).
Even if you fit an Android head unit you will still need a Resler interface, because unless I've missed something the I-Bus App is unable to access the Android Head Unit's built-in I-Bus interface, so instead utilises a USB to I-Bus interface as its way of connecting to the car.
Post #482493 3rd Jul 2018 2:13pm
dirtymonkey38
You want what Joe is selling. I remember now having to cut the cables to somewhere in the left hand boot compartment and join the wires in to connect the Resler unit. That was on a X5 though. 2011 RR Autobiography 4.4 TDV8
Post #482510 3rd Jul 2018 6:17pm
Shambler
Thanks guys Iโ€™ll look into that ๐Ÿ‘๐Ÿป๐Ÿ˜Ž๐Ÿ‘๐Ÿป
Post #482530 3rd Jul 2018 8:10pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Shambler,
I have a Resler if it helps! Would be good to buy Joe's though Wink
Bushy
Post #482545 3rd Jul 2018 9:55pm
Shambler
Just a quick update...bought a new obd cable with new drivers, all installed a piece of cake and connected fine with navcoder!
Managed to do all the tinkering I originally wanted๐Ÿ‘๐Ÿป๐Ÿ˜Ž๐Ÿ‘๐Ÿป
Post #483402 13th Jul 2018 11:49pm
Thanks for letting me know Twisted Evil Thumbs Up .
Post #483406 14th Jul 2018 12:46am
Wheelnut2000
United Kingdom 2003 Range Rover Vogue 4.4 V8 Barolo Black
Just read through this . Interesting. Donโ€™t want to faf about wiring in a resler what cable did you get in the end. Do you have a link? Thanks.
Mark
Post #490227 28th Sep 2018 7:02pm
p38arover
Australia
Has anyone managed to contact the Navcoder author in recent times? I've tried a few times over the past couple of years but had no reply. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #635182 22nd Jun 2022 1:41pm
