Home > Maintenance & Mods (L322) > 4.4TDV8 - Oil leak from front / low / right side of engine
Page 2 of 4 <1234>
GraemeS
Australia
Compare this picture with the earlier picture of the original drain. The short pipe is an extra one that empties directly into the sump rather than into the scavenger pump sump.
PS. The pipe connects at the top to the turbo using a flange and seals with a gasket, not an O-ring.
Post #482482 3rd Jul 2018 11:34am
GGDR
Hi Graeme, thanks for the info. Good to know it's a gasket vs o-ring.
I think your post here http://www.fullfatrr.com/forum/topic40047....p;start=45 proves I don't have the drain mod. What do you think?
Cheers, Greg Cheers, Greg
Post #482571 4th Jul 2018 7:14am
greg, the drain mod tsb shows your pic you posted previous on page 7 and the modified drain on page 14..hope this helps .
http://www.fullfatrr.com/gallery/albums/us...20Smke.pdf ... - .- -.
Post #482577 4th Jul 2018 8:33am
GraemeS
Australia
I spotted today that mine has caught the oil leak bug with oil all over the back of the engine. The source appears to be the oil filter/cooler housing gasket. Not really any oil forward of the housing but plenty just over the back.
Post #482579 4th Jul 2018 8:57am
have you had the mod done Graeme? ... - .- -.
Post #482580 4th Jul 2018 8:58am
GraemeS
Australia
Yes, it was done by the LR dealer at my request as a condition of the purchase. Having only travelled 18K kms the turbo was still tight so no evidence of the problem but I knew that it would become a problem sooner or later.
Post #482585 4th Jul 2018 9:14am
so whats the fix for this then.. ... - .- -.
Post #482587 4th Jul 2018 9:21am
GGDR
The fix for my oil leak?
I'm thinking about some UV oil additive, drive for a few days then get her up on a ramp with a UV light and look of the source.
Saw it on YouTube.. Cheers, Greg
Post #482588 4th Jul 2018 9:23am
Baltic Blue
Good luck Greg,
Sounds like a good plan.
Post #482589 4th Jul 2018 9:38am
like mike says, hope you find the leak. Wink ... - .- -.
Post #482591 4th Jul 2018 9:51am
GGDR
Cheers chaps. This one's been a bit sidelined by my full DPF which has taken priority!
Here's a vid on the UV Engine Oil Dye method:
Tons more like it on the Tube.
. Cheers, Greg
Post #482730 6th Jul 2018 7:51am
DrRob
Greg
Did you get the bottom if your oil leak source?
Cheers
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515580 17th May 2019 11:03am
GGDR
Hi Rob, no haven't found it.
Weirdly I ran some UV additive in the oil then had a really good hunt using a UV torch up on a ramp but it didn't show.
I thought I saw a potential source around NS exhaust lower side and tried to get a photo but the camera wouldn't focus.
So it's still wet so as yet unsolved!
. Cheers, Greg
Post #515594 17th May 2019 12:53pm
DrRob
Did you take the sump cover off to get a better look see? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515597 17th May 2019 1:04pm
GGDR
yes, had both sump covers off.
the sunspected area is a bit higher though,
visible with the wheel off, through the gap in the wheel arch.
. Cheers, Greg
Post #515598 17th May 2019 1:08pm
Page 2 of 4 <1234>
