![]() | Home > Technical (L322) > Hub nut removal |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349
IM SURE THIS IS NOT NEW , Ive done a lot of seaeching online to define the socket for the rear hub nut/driveshaft for 2004 L322 , I have decided it is a 36mm 12pt socket and I need as a 3/4 drive as I think the 1/2 " is going to snap. Can I ask if this is what I am looking for? |
Ok sorted so far , Hub nut off and driveshaft out reluctor ring was left in the hub totally goosed and adrift from driveshaft , now for replacement with new ring |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432
Not pretty |
The hub nut on the end of the driveshaft , 36mm 12pt , has to at leas 3/4 drive , very tight!
Reckon this might do it, with an impact driver and /or some trampoline legs |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
nicedayforit, nice one |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8787
just bought me one of these for undoing tricky nuts.......
| its me Member Since: 08 Mar 2013 Location: southampton Posts: 78
That will be a very powerfull tool if it will undo the hub nut. I needed a 3/4 breaker bar and a 4 ft. scaffold tube. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
A very expensive Ingersol impact I had would not look at it , so yeah 3/4 breaker bar, nut been since new I reckon. I saw the Halfords one , but half inch drive and I already had one.
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
Am I right in thinking itâs about 400 Nm? When I did my front one back up I calculated how far along the breaker bar I would need to stand to apply the correct torque as my torque wrench didnât go high enough. |
Alapat.. You mention the reluctor ring and retainer. What and where is the retainer as I didn't see one. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
Getting the hub nut off is the easy part.
^^^^supposed to have "Up to 1625Nm of "breakaway" torque ensures removal of the tighest bolts".......... There is nothing that can't be fixed with a hammerđđ
