Home > Maintenance & Mods (L322) > Centre console ashtray won't stay closed - NOW FIXED
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Me again, might as well ask this too since I seem to be on a bit of a roll Laughing
Recently the ash tray has started popping open, and takes a few goes to make it stay closed.
Is this a common thing, and is there a fix for it ?
I am guessing it means removing the centre console top. Are there details of how to do this ?
Cheers,
John. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #483283 12th Jul 2018 2:27pm
nino_nino
are You a smoker, John?
Post #483286 12th Jul 2018 2:31pm
John w
Nope, never have.
The previous owner used to keep his loose change in it, so it probably got used a lot.
I just want it to stay closed Wink Too many toys, not enough time
Post #483289 12th Jul 2018 2:54pm
gettingold
Shoot it Mr. Green
Post #483293 12th Jul 2018 4:28pm
WCA
Mine too
Logging the thread in case someone solves it before me
Post #483452 14th Jul 2018 9:21pm
GGDR
John there's a powerful UK video on console removal I saw a while back, can't find it but they do have over 200 L322 vhow to videos. It's the one where Cam-Tech-Craig's car is being done.
. Cheers, Greg
Post #483453 14th Jul 2018 9:46pm
WCA
I've been through most of their and haven't seen how to get the clip/release to tighten. If you find it, please link
Post #483454 14th Jul 2018 9:57pm
by the power of google...........
Post #483458 14th Jul 2018 10:22pm
WCA
...and the actual question was... haven't seen how to get the clip/release to tighten.
I guess it is just replace the whole thing
Post #483494 15th Jul 2018 2:43pm
GGDR
Just a pointer on how you will get to it...
Post up how you get on, I'm sure others will find useful... once you get to the problem!
Thx for posting the vid I was referring to Stan
. Cheers, Greg
Post #483495 15th Jul 2018 3:08pm
John w
Thanks for the info, it was just what I needed.
I went and had a look whilst the wife prepared dinner. It's an easy fix.
Notes to accompany the video above:
If you have ipod/ power sockets inside the arm rest, you need to pull these out and unplug them before the liner will come out.
The ipod socket doesn't come straight out, it needs to be popped out from the bottom first.
Strictly speaking you don't need to remove the unit. You can do this with it just lifted up and propped up with a towel. That means no need to unplug the terrain or gear selector unit.
Once the rear of the unit is lifted up you can see the mechanism on the passenger side.
There is a metal pin pushed into an arm that works with the latch.
On mine this pin was protruding by a couple of mm, which meant it wasn't fully pushed in.
By simply pushing it in with the key it now works as expected.
I took some pictures, but for some reason I cannot attach them Embarassed
Cheers,
Post #483521 15th Jul 2018 7:24pm
GGDR
Thumbs Up Thumbs Up
Got to love an easy fix!
Well done John.
. Cheers, Greg
Post #483522 15th Jul 2018 7:40pm
WCA
I will try next weekend and hopefully pictures.
Thanks all
Post #483533 15th Jul 2018 9:51pm
