Home > Maintenance & Mods (L322) > Thermostat and general coolant system conundrum |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
As mentioned elsewhere here had an overheat and thermostat fault last Friday evening.
12th Jul 2018 6:21pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
Hi Bushy,
12th Jul 2018 7:21pm |
Because when I pulled over with water gushing out of the lid of the expansion bottle I could spin the viscous fan blades -- I would have hoped that it would have been hot enough to have engaged -- though thinking about that a bit more -- where does the viscous get heat from to engage? if it's the rad that would have been cold as the thermostat didn't open................
12th Jul 2018 7:36pm |
........... and here's another thought, why not just cut the stat out completely and leave it out
12th Jul 2018 7:43pm |
The thermostat may well have opened but as is usually the case with our model of Range Rover the radiator gets blocked at the bottom.
12th Jul 2018 8:22pm |
Oh blimey, why did someone put a load of snot in your radiator ??? |
12th Jul 2018 8:56pm |
Ha imagine what I thought when I saw it gooping out like that
12th Jul 2018 9:03pm |
Had the car about 6 weeks, it has already done a couple of 120 mile trips without issue, I would have thought the rad would have shown before Friday, but you could be right, I'll look at it.
12th Jul 2018 9:06pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
You can remove the vicious fan on a TD6 as the engine runs so cool, and is OK in our (what was) temperate climate, but do not do this on the petrol engine. Also a thermostat is a very sensible thing, and easy to replace on the petrol engine, unlike on the diesel .
12th Jul 2018 9:28pm |
Thanks Joe, so, as mines petrol, make sure the viscous fan is working? which operates first, electric or viscous? |
12th Jul 2018 9:46pm |
The electric fan is for the air con condenser. in warmer weather this will kick in to cool the refrigerant if you have the AC on (you always have the AC on ,don't you?), the side effect being of air being blown across the coolant radiator as well, when in traffic etc.
12th Jul 2018 10:04pm |
Thanks both |
13th Jul 2018 12:00am |
Hi Bushy,
13th Jul 2018 9:51am |
Thanks good Sir |
13th Jul 2018 10:13am |
