![]() | Home > In Car Electronics (L322) > iPhone function |
MattC Member Since: 27 Oct 2016 Location: Surrey Posts: 25 ![]() ![]() ![]() |
Mine changed in the same way for no apparent reason, although i noted that once you have made a call once connected to the bluetooth the call history would be active. I ended up using the 'hey siri' function to make all calls- so much simpler and allows you to fully concentrate on the road. |
Scottjp Member Since: 15 Aug 2016 Location: Kent Posts: 36 ![]() ![]() |
Thanks for the reply.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Mine works fine - I just press call register on the screen and then press dialled calls, and all the calls I've made on the phone are all listed there, whether dialled through the car or not. Seems to also be available almost instantly when I start the car too. If thats not working, then its more likely a bluetooth setting on the phone rather than in the car. My iphone has the latest ios on it and not had a problem. Current Fleet:-
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
Have you tried deleting the phone from the system and re-pairing it? Cheers Ian
No, not tried that - i’ll give it a go |
Mine used to do that, nicksaab! |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
I had the same until I found a new option on my phone. Try the following.
Thanks for the reply - I wasn’t aware of that so will give it a go! |
Thanks chris_read, worked a treat - good old apple! |
