![]() | Home > Maintenance & Mods (L322) > Not going to get covered in oil again! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35793 ![]() ![]() |
will that need greasing up to avoid our winter road salt getting it and rusting it up.. ... - .- -.
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 ![]() ![]() ![]() |
Hopefully not Stan ,it’s brass chromed and good quality plus with the undertrays fitted it won’t get much weather I reckon. |
i'm also thinking of a worse case scenario of the tap handle being knocked by something and you loosing all the oil....happy chap arnt i |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Brilliant idea |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1236 ![]() ![]() ![]() |
Does look interesting. They offer an optional extra hose clip clamp (bottom of their home page) to prevent the tap being activated in off road conditions. How it would hold up in serious conditions I have no idea. www.ezoildrainvalve.com Tom Current Drive 2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather Previous Drives 2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather 1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather 1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic |
It was a Year ago I ordered it so cant actually remember how long it took to arrive, don't seem to think it was long. seem to remember there was a supplier in Ireland but got mine from U.S.A . Google helped!!!
Thanks |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
I just wanted to add that I know a few people who use this type of oil drain plug valve here in Toronto, Canada. I have never used one of these before but they seem fairly pleased with its quality and ease of use. No one has ever mentioned it opening up inadvertently, and no issues in the winter time with snow/grime. It does seem like a pretty practical design concept. |
RickR Member Since: 16 Aug 2018 Location: Scunthorpe Posts: 8 ![]() ![]() ![]() |
Morning all, having worked on plant machinery in the past, having to change engine oil on some machines with the engine totally enclosed and no chance of catching the drained oil we fitted a length of hydraulic pipe with the suitable fittings etc to screw into the sump. with the pipe made long enough to extend beyond the undertray and into a suitable receptacle, with the right fittings and correctly tightened if a hydraulic pipe of 2000psi + it`ll be good for sump pressure. when the job`s done cable tie the pipe up out of harms way. Sorry can`t supply pic`s as I`m doin other things these days. |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 84 ![]() ![]() ![]() |
I've used a similar item from a firm called Fumoto. Made in Japan but available from a UK supplier mine have always arrived within 48 hours of order. They have worked brilliantly on a range of vehicles.
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Im reluctant purely for the same reason Stan highlight, if it becomes undone (for any reason) the engine runs dry and you are goosed.. I may be over reacting but hey..
