![]() | Home > Maintenance & Mods (L322) > Rear susp top joint movement |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Squeaking could be coming from the inner wishbone bolts - these are "built dry". Lower ones easy to get at, upper ones less so in order to remove bolts and grease up.
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
Graeme, the joints are like a rose joint (see my pix at http://www.fullfatrr.com/forum/topic13469-15.html (scroll down).
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2776
Thanks Joe. The squeak is definitely coming from an outer joint and I'm fairly sure the bottom joint is the source. With minimal load on the top one I can cause the squeak by moving the top one sideways a little using a large screw-driver but no noise from the top.
Thanks Ron for the info but my son has lent me his bush press set.
Also check the toe bar for movement at both ends, if this is shot, it can allow "natural" movement in the rose joints .
Thanks - will do. |
| All times are GMT |
