Home > Technical (L322) > Range Rover tdv8 egr query |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
What is the actual fault code? Wynns may work but depends on what the error is. Current 2007 TDV8 Vogue Buckingham Blue |
18th Jul 2018 9:44pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
You may regret not spending money on it if the egr valves break up and kill it. Quickest fix, map out the egr's for around £150 or spend another £100 and remap the engine too. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
18th Jul 2018 11:06pm |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 385 |
CAUTION: I had that symptom before my EGR disintegrated and destroyed the engine and turbo.
18th Jul 2018 11:10pm |
Benner91 Member Since: 18 Oct 2015 Location: Belfast Posts: 81 |
19th Jul 2018 8:06am |
Is it kicking out smoke while idling badly?
19th Jul 2018 9:27am |
There is no smoke 💨 just a slight hunting of revs at cold start up
20th Jul 2018 8:14am |
lewis93 Member Since: 23 May 2017 Location: kent Posts: 27 |
Mine is chucking out P0489-00 (2C) Exhaust gas recirculation control - circuit low.
20th Jul 2018 7:20pm |
I can recommend Quantum tuning. They have agents all over so should be one reasonably close to you. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
20th Jul 2018 9:00pm |
Re blocking them out you will need to have them mapped out before you fit that ebay kit or it will throw up the fault light Current 2007 TDV8 Vogue Buckingham Blue |
21st Jul 2018 10:05am |
