![]() | Home > Maintenance & Mods (L322) > Ac only blowing out passenger vents |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Not sure but mines definitely cooler on the passenger side... |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Happened to me when I had a slight a/c refrigerant leak. Seems to prioritise the passenger side. 2012 5.0L S/C
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
How did you find it? My friend was telling me that the x5s have motors which fail on them to switch ac to not ac wonder if this could be something similar? How did you identify the leak? Current stable:
Took it to ATS. They have to check for leaks by law before refilling. They said no leaks found, refilled it. All fine for £40.
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
This may help: http://www.fullfatrr.com/forum/topic25732.html |
hmmm I don't think everyone is having what I am -
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 402 ![]() ![]() ![]() |
Failed blend motors? There are 6 of them in there.... Current:
Would that be the thing that used to chirp like a bird under the dash in the middle? Current stable:
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
How long since you had the system re-gassed? I had the same issue on the 405 (ie passenger side cool, driver and rear cooling, not cool). More info here :- http://www.fullfatrr.com/forum/topic48202.html SDV8 AB MY 2019 SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
