![]() | Home > Technical (L322) > 8 speed gearbox oil flush recommendations and advice please |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
curious to know if it drives any better Stu.. ... - .- -.
that's good to hear Stu... |
sparkyxm Member Since: 14 Jan 2018 Location: Warwickshire Posts: 2 ![]() ![]() ![]() |
Hi all,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
For your possible wheel bearing noise, check that the pipes from the ABS modulator are all properly spaced apart by the spacers. I had a right front wheel bearing replaced to no avail trying to fix this noise only to discover an unattached pipe was vibrating on an adjacent pipe well down the void. |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 ![]() ![]() ![]() |
Whats the name of the place in Selby. I need to replace a sensor too which is housed in the sump 2011 RR Autobiography 4.4 TDV8 |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
This is interesting - my 2011 was in for a megaflush and service but my indie (used for 20 years and totally trustworthy) called me up to ay you can't do a megaflush on the 8 speed box as there is a thermostat in the system that closes when the cold flush fluid hits it preventing the flush...?
That seams far too cheap sir... The oil is £48 per litre from JLR let alone the cost of the filter! |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1862 ![]() ![]() |
The 8 speed CAN be flushed without issue |
the place in Selby? Whats it called? 2011 RR Autobiography 4.4 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
As always, thanks Mike 2011 RR Autobiography 4.4 TDV8 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
saw this posted by Grofus:
Wondering if this technique is possible on the 8-speed ? Planning to change the fluid but I want to change more than the 4 that'll come out by gravity. Total capacity is 8.5litres. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
No |
Ok thanks a lot Mikey
