![]() | Home > In Car Electronics (L322) > Battery Drain from DSP |
Miserable Old Codger Member Since: 28 May 2018 Location: Cornwall Posts: 11 ![]() ![]() ![]() |
Me again,
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Despite you car having no signs of water ingress I would still be inclined to remove the dsp and take its case off to see if there are any signs of corrosion in there. Not uncommon. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
^^^ Agreed |
Thank you both for your replies,
You are indeed correct all the ecus progressively shut down. I'm not even sure that they do it in any particular order, it seems to be quite random.
Thanks a lot,
