![]() | Home > Maintenance & Mods (L322) > Why not just replace engine oil filter? |
| gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287
Good idea never thought of that. A friend at work uses one of these hand pump thingies and pumps out the oil ever 6 months via the dip stick tube, changing the oil filter yearly.
| Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182
Hi, I’d rather drop the oil than pump it out to try to get any crud out of the sump.Obviously youd change the filter at that time, I’m suggesting changing the filter alone in between normal changes seeing as they cost a tenner and would take 15 mins or so, my thinking is every little bit helps, especially when it comes to mollycoddling ya turbos! |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
I suppose how effective this is can only really be gauged once you take the second one out. If it is still serviceable and clean there would not be much point. An oil change is so easy especially with a sucker and relatively cheap (£50.00 oil and filter from Opie) that I just do the lot every 6 months. |
