![]() | Home > Maintenance & Mods (L322) > Second of many questions |
Thats not a standard JLR westfalia tow bar sir...
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
It's a brink like mine.
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
The Leather Doctor sells on ebay - exact colour match and kit will clear that up with minimal effort. |
Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56 ![]() ![]() |
thanks chaps for your replies, I will have a go at the tow bar at the weekend,
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Your interior colour looks the same as mine & is listed as Jet / Charcoal (TCX). Loads of kits on ebay just make sure that you have tinters with it, as I had to add a load of black to match my colour. |
Speak to Stacie in the land rover customer relations section on here and she will be able to provide you with a build sheet |
cheers Paul
well had a go at the tow bar, no luck, couldn't see a catch at the back as suggested so tried to undo the bolts only to find the bolt head was starting to turn but no bolt movement so stopped instead of shearing it off!
WOW what a difference, what did you use, looks brilliant |
If I remember tomorrow, I'll get my tow ball out of the boot and show you what I'm on about. |
Thanks Highroller
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
These guys do specific kits for RR colours, so matching shouldn’t be a problem
Definitely give mine a go next month when I do the oil change. |
