![]() | Home > Technical (L322) > 2002 TD6 Vogue Battery and starting issues |
Lefty Member Since: 22 Jul 2018 Location: Graaff Reinet Posts: 6 ![]() ![]() ![]() |
Check your battery connections and battery condition - suggest put on charge |
Hi, the diagnostic does not work either. all the interior lights, immobilizer led and diagnostic are dead it would seem.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Reference Joe90's post above, what voltage does your battery have, can you try jump starting from another vehicle and check battery connections?
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
Have you tried disconecting battery to reset ? |
Hooray, progress!! Checked Battery -OK, then went through fuse box and found 2 blown diagnostic fuses.
What is wrong with it?
I have recently bought the vehicle. the seller told me that it needed to be replaced and sent it with.
![]() Are you getting gearbox problems / fault messages / limp mode? Suggest some diagnostics to identify the problem... . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Hi Yes I am.
Have you done a steering wheel lock to lock, these tend to clear the "Christmas tree" effect after a battery disconnection? .
Done so but think I need to check those fuses as well. |
