Home > Maintenance & Mods (L322) > engine degreasers
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
engine degreasers
Hi all,
My car has sprung an oil leak somewhere. The under tray has oil on it.
I have removed it and can see traces of oil in various places, but want to clean it off so I can see where it's coming from.
It's not the usual oil cooler / o ring leak, I've already checked for those. It appears to be from the front somewhere.
What's the best engine degreaser, and given that room to get in there is very limited, how best to apply it?
Cheers,
John. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #484415 26th Jul 2018 10:27pm
Ant84
Bilt Hamber Surfex HD is pretty good.
Post #484417 26th Jul 2018 10:30pm
Baltic Blue
Gunk is good.
Apply it with a paintbrush. Leave it and hose it off.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #484428 27th Jul 2018 6:55am
GGDR
John I've got an unfound leak too.
So I was trying to figure out the best way to find the culprit.
I found there are these UV dye oil additives.
They work a bit like this:
- Clean the engine
- Add the UV dye
- Give it a good run
- Then inspect using a UV light
Saw some vids on YouTube. It's what I'll do once I get a few other jobs out the way.
Cheers,
Greg Cheers, Greg
Post #484431 27th Jul 2018 7:28am
GGDR
There are many out there, here's one:
https://www.ebay.co.uk/itm/UV-Dye-Torch-Ki...0754744531
Comes with a torch too.
Let me know what you think. Cheers, Greg
Post #484432 27th Jul 2018 7:30am
nino_nino
John w, when I hade oil leak from the front it was plug on the top of the oil pump. link wit pictures:
http://www.fullfatrr.com/forum/topic44161....+leak+fron
for cleaning oil I use brake cleaner with adicion of long vinile tube. it work very well.
Nino,
Post #484437 27th Jul 2018 9:28am
John w
Thanks guys. Thumbs Up
I have used gunk, just wondered if things had moved on and there was anything better.
Trying to get in to the areas with a brush would be a challenge, so I have bought some gunk in a spray bottle, and also some foaming cleaner.
We shall see how it goes.
Havent done it yet as its chucking it down here now. It seems like it is near side front. There is misted oil below what I assume is the maf or throttle body (which doesn't look like a very tight fit).
I might have to drop the front to get a decent look.
Thanks for the suggestion of the uv dye, I hadn't considered that Thumbs Up Too many toys, not enough time
Post #484458 27th Jul 2018 4:39pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Jizer was always good degreaser, Gunk is good stuff but smells awful and the smell stays for ages. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #484462 27th Jul 2018 5:29pm
