![]() | Home > Maintenance & Mods (L405) > How to undo L405 front grille? |
Screwdriver in the slot and prise/slide the inner upwards then remove the four clips... You will then need a long flat screwdriver to twist the four push in clips at the bottom of the grille |
The lower clips are very similar to those found on a 322 Grille... Shown in this video |
Thanks Craig, very much appreciated |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
Powerful actually have a video on the L405 grill |
Thanks.
I don't much like the idea of hanging off the grille to try and "unpop" the clips! The use of a long pry bar is much more reliable |
