Home > Technical (L322) > Engine System Fault
davidjpowell
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Engine System Fault
Hi having problems with a 3.6 tdV8. Really bad timing as i'm stretched at the moment. Trying to find out if this is a wallet breaker, or merely a denter.
Car is going into limp at 50mph with Engine System Fault. It's not triggering any fault codes that my code reader, or indeed the AA's can see.
I think its performance is reduced I think, and it is very sooty with black smoke. I don't think it's the boost hoses.
It does smell very diesely under the bonnet, and the underside of the top cover looks contaminated towards the rear left...
Any ideas any one please?
Post #484838 31st Jul 2018 9:17pm
Split hose (one of many going into the inlet manifiold): £
Knackered EGR Valve: £££
Knackered Turbo: ££££
Hoping it is just the first one
Sorry Neutral .
Post #484839 31st Jul 2018 9:22pm
davidjpowell
hmm. It's about what I feared.... Thanks
Post #484840 31st Jul 2018 9:28pm
Have you got any further with you engine problem? .
Post #485410 7th Aug 2018 6:01pm
davidjpowell
It’s been in diagnosing today.
Cracked manifold. £900 of ouch. Could be worse I suppose
Post #485411 7th Aug 2018 6:04pm
Zoiks Shocked .
Post #485416 7th Aug 2018 6:29pm
davidjpowell
It is worse.... £900 + VAT apparently...
Post #485424 7th Aug 2018 9:09pm
Have you seen this thread
http://www.fullfatrr.com/forum/topic44256.html
A "magic goo" repair could work wonders, and a lot less than +£1K Thumbs Up .
Post #485577 9th Aug 2018 9:28pm
ptaroni
Sikaflex used on mine as the above post as the drivers side manifold had split and was on back order! Must have covered atleast 800 miles with no issues! Will eventually get round to fitting new manifold at some point! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488307 7th Sep 2018 6:01pm
