|  | Home > Technical (L322) > RSD - Random Suspension Drop? SOLVED |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287      | Also worth checking the reservoir underneath they do corrode and can leak   | ||
|  2nd Feb 2018 1:50pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | ^.......and associated pipework.  | ||
|  2nd Feb 2018 3:32pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | I posted this a while back, and it's been mostly behaving. Until yesterday and came out of work to find the rear end sitting on the stops.
|  29th Jun 2018 6:41am |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Haven't been under the car yet but found this in the workshop manual:
 Might explain the random drop and how the sensor could be the culprit. It doesn't always drop (hence thread title!) but I want to know if it's a slow leak. I went to the car four times yesterday and measured the height and it was stable all day. But some days like earlier this week, it will be on the bumps. I think the Periodic Re-leveling coupled with a bad sensor/connection fits the symptoms. Also the code ^ does not say LH or RH which is weird. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway | ||
|  30th Jun 2018 7:16am |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    |
 Your screenshot says "rear right height sensor"....  . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember   Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 | ||
|  30th Jun 2018 9:35am |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Ah Joe - thank you - I must be dyslexic I really didn't see that...
|  30th Jun 2018 9:37am |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Hi Team,
|  22nd Jul 2018 8:14pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | The valve is easily unclipped from its 3 pronged mounts then lowered although you might want to remove the liner for best access.  I had mine out a week ago when swapping front and rear valve blocks tracking down the reason for the front lowering overnight.
|  22nd Jul 2018 9:16pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Just a minor update; as above ^^  I re-plugged the connector with some contact get and lashed up the exposed wires and open conduit with electrical tape two weeks ago.
|  5th Aug 2018 6:46am |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690      | Greg, why not apply same treatment to remaining tree sensors. it won't hurt none.  | ||
|  5th Aug 2018 7:01am |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Definitely Nino, I already did the other side rear. I put this stuff on any connectors I remove, inside or out.
|  5th Aug 2018 7:11am |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690      | I use CorrosionX, first recommended by Haylands.
|  5th Aug 2018 7:47am |
| Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282      | Don't know if this is related but I am new to ffrr and coming from disco to ffrr but a lot of disco owners where getting gremlins in the electrics due to using car washes , the high pressure hoses wetting out and corroding connectors mine only got a blast after off roading , but having said that they are all Landrover and as we know they just do what they want and back Again for no reason . I am a big believer in undersealing and mine will be getting the full treatment once I know how she goes , for me it protects electrics and b/pipes etc from corrosion
|  5th Aug 2018 12:39pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | @henda
|  5th Aug 2018 3:43pm |
| Posting Rules
