![]() | Home > Maintenance & Mods (L405) > Land Rover OEM flange tow bar question... |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
Email sent. Incidentally the bolt seems to be 16mm. Only Range Rovers since 1988 |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 288 ![]() ![]() ![]() |
Bit puzzled to read different versions of the fitting instructions. The design I’m guessing has changed since 2016 (date of my owner’s manual) to the online version which I’ve uploaded here. The current (online) section of the manual refers to the anti-rattle bolt - see 5 & 6 in the picture.
That must be right, the later ones have the anti rattle bolt and my guess is that it is from MY 2017 on. Only Range Rovers since 1988 |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 103 ![]() ![]() ![]() |
[quote="Red Merle"]
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
No problem.
There you go:
rw90 Member Since: 07 Mar 2019 Location: Scotland Posts: 35 ![]() ![]() ![]() |
I saw those when I was looking for mine, although the much heavier duty ones will let you use a great deal more pressure to clamp the joint together |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 251 ![]() ![]() ![]() |
I had a tow hook fitted and two points:-
A little unfair. A receiver hitch can easily be locked into place: https://rover.ebay.com/rover/0/0/0?mpre=ht...2992582344 https://www.amazon.com/Heininger-6013-Hitc...&psc=1 https://www.amazon.com/gp/aw/d/B07PQ6D8G6/...&psc=1 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
Well is still had a single bolt in the same place that would allow it to be removed...... If you lock the bikes together, then even if you can remove the pin, it's still a significant feat to move the whole lot with that weight. It's the same system used by the Americans & Australians, so plenty of locking pins out there too. |
Thanks both for responses.
The swan neck tow ball had a lock that simply locked the 2 parts together - which gave the illusion of security......
Ohh... I just put it on and left it ..never examined it closely. It had a lock assumed that secured it. --
